zetec turbo boost
3 posts • Page 1 of 1
zetec turbo boost
If I run a decompression plate on a 1.8 black top zetec engine what's the maximum boost you can run?
I have got a external wastegate set up which has an 11 psi spring in it. Would that be ok to run?
doRSet lee b
- doRSet lee b
Re: zetec turbo boost
From what iv seen most people say not to run anymore than 12 psi on de comp plate so you should be ok. just make sure the fueling is set up properly
- russ-RST
- Your car: fiesta rs turbo
Thanks for the advice. I have read so many different things and it's hard to know what to trust. Guess it's just try it and see.
doRSet lee b
- doRSet lee b
