Zetec turbo engine, intercoolers and last of the bits i have
9 posts • Page 1 of 1
Thought i'd do a new thread to tidy it up.
Bits i have left now are:
Un run blacktop Zetec turbo engine, Crazy cage custom engine mount, Plate to mod standard cvh mount if preferred, Peugeot 306 GTI valvesprings with washer to raise spring pressure,New genuine Ford Focus RS plugs, C20LET pistons, Steel rods, ACL bearings, new stainless hardware throughout, new oil pressure switch, all parts stripped, cleaned and painted.Rready to run!! Fitted with silvertop sump so you can run front or rear starter set up! Extra idler pulley and custom bracket for using front mounted alternator. £1250
New and unused Universal intercooler meduim, new £60 665mm x 240mm x 70mm, Pipes are 55mm inside diameter
New and unused large intercooler, measures 780mm to the widest part of the pipes, 300mm tall and 75mm thick.
It has threaded bosses on the top and bottom to mount the cooler.
Also have the Airtec largest alloy rad, unused in black, measures 640mm x 330mm ( same as fitted to the car pictured above ) £223 new, £170
http://www.autospecialists.co.uk/Stage-2-50mm-core-AIRTEC-Fiesta-RS-Turbo-all-alloy-radiator-Product-863.html
12 bore front bumper £50 ( looks like the focus RS Mk1 bumper, fiesta fitment ) Bought this to use as its the ultimate bumper for airflow to the rad and cooler.
Euro rear lamps with gaskets, lovely condition, one small nick out of the passenger side but not noticable when bootlid closed £90
Fiesta MK3 clear rear lamps £30
New unused FRST header tank ( still with ford stickers on ) £40
-10 speedflow fittings, brand new. £20
Brand new Cosworth crank sensor £15 posted
Tested weber ignition amplifier £25 delivered
Roll cage steering wheel hook, alloy. £15 delivered
Tested, working with no missfires, Coil pack £25 posted
Focus St170 front calipers, carriers and bolts. Slight rip to dust seal but fine to use as is. £40
Please call or text for a quicker response, Gary 07946367994
- Gadget
- Your car: 05 Mondeo ST Tdci & FRST
Re: Zetec turbo engine, intercoolers and last of the bits i have
Do you have any carbon panels left like bonnet or roof?
- robp-tt
No mate, everything is sold other than what's listed
- Gadget
i hope you what you got back from the car financially was worth it mate..shame but needs must
- FRSJON
FRSJON :i hope you what you got back from the car financially was worth it mate..shame but needs must
I've got back just under £6500 so far without these bits that are listed so I think I've done ok, never would've got £7500 for the car built up and running. I wanted to finish it but thought it pointless using it then stripping it to sell to get the money back, and then the parts wouldn't be new so probably worth less!
Not too fussed if the engine doesn't sell as I'm considering getting a mk1 focus rs!
- Gadget
well the engine has sold now
- JBarton
- Your car: mk3 fez
JBarton :well the engine has sold now
Check your inbox mate
- Rhinopower
- Your car: Volvo FH330
Only 2 years late but did the engine sell pal?
Adam
Adam
- Adambridgey
- Your car: BMW M3
Adambridgey :Only 2 years late but did the engine sell pal?
Adam
Wow! This is an old post, yes, the engine sold.
It made 397 bhp with still some mapping to finish so well chuffed with that!
- Gadget
