Zetec Turbo engine - whats it worth?
30 posts • Page 1 of 1
zetec turbo engine, never been started or ran
2ltr block rebored to 86mm
calibra turbo pistons (new rings) on zetec rods
ARP rod bolts
new big end and main bearing shells
new main bearing cap bolts
new oil pump
new water pump
breather under exhaust manifold blocked
2 new breather ports fitted
turbo oil return fitted
1.8 sump and oil pickup
cylinder head drilled and tapped for fitment of Escort RS Turbo exhaust manifold
valves lapped in
new valve stem oil seals
Rocker cover silver with black FORD and DOOHC 16V lettering
RS Turbo manifold included but no turbo, all new gaskets but no head gasket
whats this worth?
ARP rod bolts
new oil pump
new water pump
valves lapped in
whats this worth?
RS1600i restore, weld in multipoint cage, t34 zetec turbo
http://www.passionford.com/forum/viewtopic.php?t=130905
- Red16
Is it worth the laughter in which you'd be immersed when I fitted it into the Metro? If so, I'll take it and put it in there, no joke
bttt
- Red16
i'd say about £200 now can i buy it lol
i'd be prepared to pay about £1000 for it maybe even a bit more, but ive got my engine now
xr2 turbo
- joel_winders
no can do on the finance fron... im as brassic as the next bloke
- Red16
hhmmmm, dont think i can afford that then, would love it, so would my mechanic, more money for him, but dont think his missus would be happy if i got it
- RosscoPeeco
s2turbo it was off ebay for about 10 quid. looks nice but the pegs its screwed into need cutting down slightly as you can see in the photo it sits a tad higher than the rocker cover, easy done tho
RosscoPeeco you girl would love it mate
- Red16
- lazy_arse_pie
engine management, inlet manifold, alternator and flywheel, not a problem if its going in a fiesta turbo, head gasket, timing belt, alternator belt
- Red16
bump
- Red16
xr2i_babe :how do u no it will run tho as its never been run. compression could be out etc?
dont no how the full zetec engines work but ive had alot problem from my zetec bottom end
what do you mean by the compression could be out
its a new build engine, any competant mechanic could build an engine up without much hasstle. all new parts have been used etc
as for yours, well, id have a word with who ever built it.
- ianFRST
compression etc on the engine will be spot on, block has just been rebored to accept the larger diameter forged vauxhall pistons, new piston rings fitted and all 16 valves lapped in and leak tested
it was originally destined to go in my Clio 16v in place of the williams engine thats in ther now, but i planned on fitting it into my Escort RS1600i not a S1
i was just geting an idea of what its worth to people because im interested in selling it as i want to build a new higher spec engine for my RS16i.
- Red16
xr2i_babe :What turbo is it designed for, and would a T3 go straight on and run right?
Check out his sig. T34. What do you mean by "designed for"?
i was planning on using the t34 i have but a t3 would be fine
its up for sale now on ebay
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 4570195014
- Red16
yeah the t3 will fit straight onto the manifold on the engine
- Red16
[color=red]PLEASE PLEASE HELP ME [/col(ESCORT RS TURBO SUMP)
CAN SOMEONE PLEASE HELP I HAVE A FIESTA RS TURBO WITH A T3 CONVERSION AND IT KEEPS BLOWING TURBO'S AND I HAVE BEEN TOLD THAT I HAVE TO PUT A ESCORT RS TURBO SUMP ON INSTEAD AS THE ESCORT SUMP HAS THE OIL RETURN GOING INTO THE SUMP AND NOT THE BLOCK LIKE MINE ON THE FIESTA
CAN SOMEONE HELP ME GET THIS CAR WORKING RIGHT GOD DAM
- maddogwhite(29)
