zetec turbo guys, what turbo you got?
19 posts • Page 1 of 1
hi there, brief spec of what my engine will be...
2.0 16v zetec series 2 (silvertop)
forged pistons
steel rods
rover inlet
cossie lights greens (think i will change them to dark greens)
cossie 2wd throttle body
stainless tubalur manifold
external wastegate
big front mount ic
stage 1 port, standard valves etc
Prob look at some turbo specd cams (well most deffinately will get some)
full balanced bottom end
lightened flywheel
mtx75 gearbox
im wanting around 300bhp, it's not gona be an everyday car, gona be built for trackdays etc
Now what turbo would you guys recomend?
forged pistons
steel rods
rover inlet
external wastegate
big front mount ic
lightened flywheel
mtx75 gearbox
- SamT
what about a gt28r from here? i know its not a garrett but???
anyone had dealings with them? seems alot cheaper than any other iv seen so far, plus the exchange rate at the mo makes it nearly half price with a £ sign. Says on the site shipping $100 seems ok. i'd have to double check tho. Any one got any ideas on how much import tax i would have to pay
http://www.ssautochrome.com/level.itml/icOid/1489
- SamT
I Have a 300bhp ZT and im thinking of upgrading to a T34 i currently using a T3 but with the amount of power a T34 will be better just my 2cents
- jimmyc_2006
wts the spec of your engine mate? and what t3 were you using. What kinda torque were you getting aswel? cheers
iv actually been swaying towards a t34 aswell. would the gt28rs even be good enough for 300bhp? and also im thinking about traction aswell because the t28 is gona hit boost alot quicker, so maybe i would be better off using a bigger turbo?
- SamT
Ruishy1 :those turbo's are made of cheese. And mouldy old stuff at that
Any one of the six turbo's above in particular?
Sounds as though you need to find out what flange is on your fannymould also. This would dictate alot of what turbochargers you are limited too.
Steve
Steve
- Captain Tightpants
if all that's read is to be believed, the GT28 is the one to go for as its got next to no lag allegedly, whereas the t34 is a tad laggy.
t34 cosworth turbo exhaust housing is 0.63
garyhurn77 :i ll be running a t34 with 0.48 exhaust housing on my 2.1 zvh same spec as the cosworth turbos
RS1600i restore, weld in multipoint cage, t34 zetec turbo
http://www.passionford.com/forum/viewtopic.php?t=130905
- Red16
