zetec turbo pistons and cams
20 posts • Page 1 of 1
can anyone recommend a decent set of cams and pistons to get for a 2.1 zetec turbo?
im sure i read somewhere that ford cams are ideal but want to double check and start amassing the parts in one go so i can build it all up and bolt it in rather than do the bottom end, then start doing the head etc.....
- xrsi
- XR(ustyAtTheMo)SI
Re: zetec turbo pistons and cams
xrsi :can anyone recommend a decent set of cams and pistons to get for a 2.1 zetec turbo?
rods and pistons from the us and a standard st170 head with the right turbo will do 400bhp
- crazycage
Yes, Ford cams are fine for most applications, It just depends on what power you are hoping for.
JE Pistons or CP pistons seem to get good reviews.
I have parts for sale!!!!.....Nice parts too!!!
http://www.fiestaturbo.com/forums/lots-of-parts-for-sale-vt185591/
- MattPym
Cp pistons - eagle rods..
cams speak to Ian Howell- best to buy a cam that has been proven,
what power do you want
- luca
want very high 200's or 300ish is the figure im looking for!
have sorted a price for all the arp bolts, and also the eagle rods. just cant find any pistons.
Cam may well stick with ford ones then if they are up to the job, then in a coupld of months change the cams for area 6 ones.
- xrsi
- XR(ustyAtTheMo)SI
rs 1800 exhaust cam is a must i can tell you that!!!
pistons well your looking at £600 really for cp pistons, they are the best you can get.
- luca
i bought these last month and only took 5 days to get here only about £250 with rings to your door
http://www.nolimitmotorsport.com/prod/JE185915
- crazycage
they are still 85mm pistons, im looking for 86mm to get the 2.1 capacity.
That saying, im having a big problem trying to find any 86mm pistons!
- xrsi
- XR(ustyAtTheMo)SI
xrsi :they are still 85mm pistons, im looking for 86mm to get the 2.1 capacity.
Unless you go Calibra Turbo LET pistons, I think you'll have to custom order the pistons! Although I think Wossner or Performance Engine Components do 86mm pistons!
- MattPym
why tho its not like it will make more power but its your money if you want to spend £600 on pistons when you can get them for less than half that then thats upto you
- crazycage
i appreciate that mate, but if im doing something its going to be done right first as last as i am sick of thinking about how bits should have been done at the time!
- xrsi
- XR(ustyAtTheMo)SI
xrsi :i appreciate that mate, but if im doing something its going to be done right first as last as i am sick of thinking about how bits should have been done at the time!
i understand that you want to do it right and you would be with them pistons you still need a rebore with them there not standard size and good what ever power you can get out of a zetec
- crazycage
out of a 2ltr and a 2.1 you will get more torque from the 2.1 for the same modifications 9 times out of 10.
i may just bite the bullet and get the above pistons anyways as that would decrease the buget alot and leave funds for other area's, at end of day what is 0.05ltrs (as the above will give 2.05 approx) and with good mapping will prob be more than enough for what i want.
- xrsi
- XR(ustyAtTheMo)SI
xrsi :out of a 2ltr and a 2.1 you will get more torque from the 2.1 for the same modifications 9 times out of 10.
get a st170 head and cams will do 400 bhp standard with the vvt thats what im using
- crazycage
crazycage :i bought these last month and only took 5 days to get here only about £250 with rings to your door
excellent pistons for the money i've been running thses pistons they can handle a lot of heat..
sean
gt 2876r aka gt25/40r roller bearing turbo, L8 ecu, 850cc injectors mapped by msd to 12psi with LC & AL closed loop 30+ psi soon
0-100 10.84 100-150 9.24 154mph daddy thrash 06
- turboboss
wossner pistons make standard size 85mm and 86mm pistons.
- creator
creator :wossner pistons make standard size 85mm and 86mm pistons.
have you not seen how old this post is?
ive built up the engine and its currently being installed in the car with custom mounts at Jamsport!
- xrsi
- XR(ustyAtTheMo)SI
so over a year on.........
did you go for the same as crazy cage?? are these still available as i am doing a 2.1l zetec turbo at the end of the year
@crazycage
have you experianced any problems with these pistons? you running a lot more power now?
@crazycage
- dangerousdave
xrsi :creator :wossner pistons make standard size 85mm and 86mm pistons.
sorry lol
- creator
dangerousdave :so over a year on.........
@crazycage
have a loo in the members gallerys to finfd the engine build thread
- xrsi
- XR(ustyAtTheMo)SI
