Zetec turbo pistons
17 posts • Page 1 of 1
Zetec turbo pistons
Just a quick one
Ive picked up some cosworth frs wrc conrods to put in a zetec silvertop turbo
Im unsure what pistons to put in the silvertop wont go in because of the gudgen pin side so im wondering will the frs ones be fine to go in?
Unsure wether to go forged or get hold of some standard ones but what bhp would they be safe up to? Also would they be tight in the bores going in a 2.0 with just a hone to bed in the rings?
- escortdriver1
- Your car: cosworth replica ZT project
Re: Zetec turbo pistons
If you wish to use standard focus rs pistons you will have to have them fitted into A brand new block Because of the size of the pistons if you put them in a seasoned block they will not seal properly
- russ-RST
- Your car: fiesta rs turbo
O right lol how would i get hold of a new 2.0 block mate?
If not would 2.1 be the way and have it bored?
- escortdriver1
it would be a waste of time fitting steel rods to cast pistons..if there i-beam ones then buy some nice pistons for them or fit some c20let (calibra turbo) ones as im 99% sure the pin size is the same.. did you buy these rods off of ebay?
- FRSJON
http://www.ebay.co.uk/itm/focus-rs-mk1- ... true&rt=nc
there these mate i think there the I beam ones,
and the c20let are apparently 21mm and the FRS are 22
- escortdriver1
escortdriver1 :http://www.ebay.co.uk/itm/focus-rs-mk1-conrod-zetec-turbo-steel-conrods-/261183584066?_trksid=p2047675.l2557&ssPageName=STRK%3AMEWAX%3AIT&nma=true&si=E4pXbUfY8aC6TemVNwijR3jOOCk%253D&orig_cvip=true&rt=nc
have you measured the little end? ive had these rods with LET pistons but mine might of been rebushed...plus i was gutted when these sold as they were a bloody bargain
- FRSJON
Im using a set of brand new frs pistons from graham goode for £260 posted, in a lightly used block. No reason you can't do the same. Your using brand new rings, no reason it wont seal.
- Rhinopower
- Your car: Volvo FH330
Lol sorry mate, and was well chuffed with the price they havent turned up yet to measure them but theres a thread on pasionford that says they are 22mm and the c20let is 21, i supose i could try and find somewhere that may make new bushes that are slightly smaller if need be.
Or the standard focus rs pistons was the other option but i cant get a 2.0 zetec thats done under 100k
Im just woried the pistons wont be tight enough in the bores as ive felt the movement in another engine and the pistons were moving about 2mm ish in the bores dont know if this is normal or not?
And i have heard horror stories about the fra pistons melting and no-body seems to know where to get piston rings for them
- escortdriver1
if the there not the same as let pistons then find a alternative. as said above focus rs ones are still available.
rhino- did you get rings with the pistons? didnt think they were available?
- FRSJON
Yeah rings came with pistons Jon
- Rhinopower
Rhinopower :Yeah rings came with pistons Jon
nice one ,for the money then its the way to go
- FRSJON
Zetec turbo pistons
I run those rods with forged omega pistons.
Engine was professionally build so I'm unsure of the size of the small end but I'm 100% it was machined to fit.
Best rods money can buy really!
- SEG1
Yeah it does sond like the cheapest and easiest bet to be honest, would they fit ok in a used 2.0 bore? Or around what mialage engine would be the best to look for for a good bore to fit these into? Just woried about them sealing
Would the omega pistons require a bore to fit?
- escortdriver1
Zetec turbo pistons
Omega pistons will need a bore as they are for a c20let engine.
They are available in 86mm 86.5mm and 87mm.
There not cheap though.
- SEG1
- FRSJON
Just saw those, bargain!
- Rhinopower
i used to run these rods , there a very odd size 1mm longer than silvertop rods and about 4mm shorter than blacktop ones . pistons need to be custom made for the rods.
i have wrecked two of mine and had i seen these i would of bought them
if you want to sell them let me no
- crazycage
