Zetec turbo power predictions? : Tuning / Handling / Braking - Page 2 | Fiesta Forums
Postby BUTRE on Tue Dec 12, 2006 2:41 pm
heeman10 :
turboboss : i have just found out how to setup my boost controller to have a different pressure per gear.
Don't you use a Turbosmart eBoost controller? I wasn't aware of them being gear-mappable? Quality if it is, that'll sort all sorts of problems and make you a damn sight better off the line no doubt! Bet it'll only need about 8psi in first then you can be away and on the move! Good news about the driveshafts :)
It's funny you say that about the big power FWD Fords coming out next year. I was reeeeeeeally looking forward to the summer and tail end of this year, there seemed to be at least four 600+bhp Escort Cosworths in the final stages of completion a few months ago, but hardly any have surfaced :-?
On a manual gearbox, how can any ecu know at what gear you are??? I really need to know this :wink:
For experience, I don't give a deadline to anyone about when my car is going to be ready, and I belive that no one should do it either since there is always something going wrong, beeing delayed, going diferent route, etc
I bet that everyone is trying to go to TOTB with the new setups :Q
BUTRE
Postby heeman10 on Tue Dec 12, 2006 5:11 pm
BUTRE :On a manual gearbox, how can any ecu know at what gear you are??? I really need to know this :wink:
I don't know yet, it must be a fairly funky little sensor/ECU that carries out the function though. Never seen one or read a description of such a system.
Postby bassboy on Fri Dec 15, 2006 1:05 pm
turboboss :
bassboy :
turboboss :
heeman10 :The proper turbo was ditched in the last week or two. Shame, but it can always be slapped on later I'm sure :D What have you done with yours since the day at SCC Sean? I completely forgot to call you the following day :rolleyes: Sounded as though you were going to be busy anyway..
hi m8
yeah was busy on sunday i ran the car at the performance ford daddy thrash really good day never pushed the car that hard, ended up destroying my head gasket at times i was running 31psi silly me hit the rev limiter using nitrous which is a big no no so i did'nt expect it to last.. so on my shopping list is a wideband 02 & egt gauge not cheap but its a must, and a bigger turbo exhaust housing going from 0.64 to 0.84 i'll have to get christmas out of the way first...
sean i still have the clips on camera ;) ill burn you a copy and give them to ya when i see you next :Q :Q
went out in sme of the fastest cars i have ever been in....Seans and Paul's Black NMS S2 :Q :Q :aviator: Sean...like the way you said you werent going for it and when we saw the top seed flash up :lol: :lol: :lol: :lol:
bassboy
thanks bassboy
top speed runs are gooooooooo but i need to do more i cant wait for next year so many big power fwd fords should be ready. i'm going to order my uprated driveshafts, and i have just found out how to setup my boost controller to have a different pressure per gear. i'll also have to speak to bernie to gain my top speed i have to drop my final drive to suit the engine. he is always going on about how the standard 3.82 final drive suits the engine Characteristics but it does'nt suit mine.
by the way bassboy what would a t70 turbo be like on my car i can get hold of one very cheap, only done a few hundred miles comes off a famous cosworth.
too big mate not worth the hassle...but i would like to use somehng a bit bigger than that if i can on a different engine that i have been specc'ing up :Q
bassboy
bassboy
Authorised Trader
Authorised Trader
Postby bassboy on Fri Dec 15, 2006 1:06 pm
heeman10 :
IIRC there is are micro switches on the gear linkage that allows the ECU to know what boost/fuel to run
bassboy
bassboy
Authorised Trader
Authorised Trader
Postby BUTRE on Fri Dec 15, 2006 1:12 pm
bassboy :
heeman10 :
bassboy
Hum... where to buy this from?
BUTRE
Postby bassboy on Fri Dec 15, 2006 1:18 pm
BUTRE :
bassboy :
heeman10 :
bassboy
im not 100% mate but IIRC again, pectel offer this and its a feature on my ECU ;)
bassboy
bassboy
Authorised Trader
Authorised Trader
Postby heeman10 on Fri Dec 15, 2006 1:45 pm
That's the only way it can be done, I want to see pics though :p
Postby BUTRE on Fri Dec 15, 2006 2:13 pm
hum... have to try to sort that once again...
Had this years ago for my clio but never sorted the sensor to light it up:
http://img.photobucket.com/albums/v11/P ... icator.jpg
BUTRE
Postby heeman10 on Fri Dec 15, 2006 2:30 pm
What type of sensor were you trying to use?
Postby bassboy on Fri Dec 15, 2006 2:53 pm
heeman10 :That's the only way it can be done, I want to see pics though :p
you aint getting them from me LOL :bonkers: :bonkers: i dont think ill be using the function though as Ahmed was telling me another method that i need to look into yet
bassboy
bassboy
Authorised Trader
Authorised Trader
Postby essexrsturbo on Sun Dec 17, 2006 4:20 pm
looks like a good project bassboy. wish i still had mine
essexrsturbo
Postby bassboy on Mon Dec 18, 2006 10:42 pm
essexrsturbo :looks like a good project bassboy. wish i still had mine
i know mate...i heard about the car on passionford....such rubbish about the car going missing....have you had any news so far?
bassboy
bassboy
Authorised Trader
Authorised Trader
Postby Captain Tightpants on Tue Dec 19, 2006 12:57 am
If there is a speed sensor on the car, the ECU will be able to work out what gear your in, using a simple RPM/Speed table.
Steve
Captain Tightpants
Postby heeman10 on Tue Dec 19, 2006 2:32 pm
Scort :If there is a speed sensor on the car, the ECU will be able to work out what gear your in, using a simple RPM/Speed table.
Steve
I'm even falling behind the Scortmeister in knowledge! Bloody unemployment! :x
Previous
