Zetec turbo using OFAB
4 posts • Page 1 of 1
Hi, I'm (slowly)building a ZT for my car. i've recently got an OFAB loom and ECU.
I'm curion now as to what sensors i would need to swap from my current Zetec to OFAB items. i know i iwll need to sort a MAP sensor, are these the same as the cosworth ones?
I will be using the FRST inlet manifold so TPS isnt a prblem
JJ
JJ
Is that the best you can do?
- jdfiesta
- Your car: V70 T5
BTTT
someone must know this
JJ
JJ
- jdfiesta
- Your car: V70 T5
Use all the sensors mate.
I'm pretty sure the Speed sensor is the same as a zetec though.
TPS, CPS, CTS, MAP and ACT should all be from a FRST.
Steve
Steve
- Captain Tightpants
Cheers Steve
looks like i best get shopping around
JJ
JJ
- jdfiesta
- Your car: V70 T5
