zetec turbo
3 posts • Page 1 of 1
zetec turbo
what do i have 2 do 2 run a low boost set up on a 2.0 16v mondy engine ive got a decomp plate, t3 with manifold and adpation plate
what else do i need ??
and what do i have 2 do 2 then engine its self??
thanks alot
thanks alot
- phyllip
Re: zetec turbo
phyllip :what do i have 2 do 2 run a low boost set up on a 2.0 16v mondy engine ive got a decomp plate, t3 with manifold and adpation plate
thanks alot
Well if you havent already you will need to mod certain things to fit the 2.0ltr engine into a fiesta to start with.
You will need (off top of my head so may miss some things)
turbo oil feed pipe
oil return to the sump, so will need to make a modification to the sump pan
uprated fuel pump
better injectors
exhaust downpipe from t3 to rest of exhaust
extra breather on rear of block
intercooler
pipework for intercooler/turbo/air filter
probably have to make alterations for rad anf fan depending on set up with the intercooler
a better clutch
and last of what i can think of, engine management.. so either aftermarket or use rs turbo loom and ecu, which then needs properly setting up
- happypaul
Re: zetec turbo
I'd suggest checking out the guides section on this very site it has everything you need to know on this subject
does my big look arse in this?
- The Gilly
