Zoo lower arms/Rose jointed adjustable ones
19 posts • Page 1 of 1
Seeing Zoo is no longer trading and the only rose jointed lower arms on the market are Area six ones and they are only adjustable for camber to a small amount
Would anyone be interested in some tubular rose jointed camber & caster adjustable lower arms, these ones will have more adjustment than the zoo one?
- freak power
Re: Zoo lower arms/Rose jointed adjustable ones
yes any idea on a price?
- frostie
That i can't say just yet until the company had made them
- freak power
these would be easy enough to make up, so shouldnt be too expensive.
- Ruishy1
Ruishy1 :these would be easy enough to make up, so shouldnt be too expensive.
Not as simple as you think as the right rose joints to use don't come cheap and there offering more adjustment than the zoo ones so thats more expense
One more thing is that they will be CNC machined so you will be looking at a price a bit more than the zoo ones witch were £350
- freak power
As I mentioned in my PM regarding the rear beam a while ago I would be interested in these. Would there be any discount for purchasing a rear beam and wish bones together?
- Makaveli
freak power :Ruishy1 :these would be easy enough to make up, so shouldnt be too expensive.
the bearings are not expensive http://www.rallydesign.co.uk/index.php? ... dhjplee4q7
and i refer to your first post
freak power :Would anyone be interested in some tubular rose jointed camber & caster adjustable lower arms, these ones will have more adjustment than the zoo one?
tubular isnt something you cnc machine, i looked at making up completely adjustable lower arm, and i reckon i could have dont it for around 150 quid a set.
using roughly those spec rod ends, and ally tubing to make up the frame of the arm
- Ruishy1
Rally design's Clubman rose joints are S**t, they done have the right load rating and wrong max angle, There cheap for a reason. i would never get the Clubman rose joints and use them for anything needed at high load .
Well they wouldn't be made from tube but from billet for strength, Ok i did a miss type.
You make your own then.
Makavell i'm sure a price can be arranged for both
- freak power
could be interested in a set of these
Lower than a snakes bollox
- Big Walker
- Your car: Seat Ibiza
tube is perfectly acceptable for lower arms aslong as it was correctly speced!
- xrsi
- XR(ustyAtTheMo)SI
You could be looking at £350 for camber and caster adjustable CNC machined arms
- freak power
Should be out in feb 09
- freak power
Cool, eager to see some pics. What grade are you using material wise?
- Makaveli
Just a high grade steel
They will not be made out of tube, they will be machined from solid bars on a CNC
- freak power
seemless tube is better than solid bar and also cheaper by the time you have had it cnc'ed, bit pointless having it cnc'ed in terms of cost time for no gain at all!
if same grade material is use as would have been used in bar then it will be alot heavier and wont be any stronger.
- xrsi
- XR(ustyAtTheMo)SI
put me down on the list for these aswell please
Formally Andyswidefez
Yes, i have a fat RS! lol
BIASmotorsport
- AndysFatRS
xrsi :seemless tube is better than solid bar and also cheaper by the time you have had it cnc'ed, bit pointless having it cnc'ed in terms of cost time for no gain at all!
You haven't seen the design, they need to be solid bars, if i used seamless tube then welding would be needed for this design.
- freak power
I don't see trader status and this doesn't look like a group buy since there's no price breaks mentioned. Please either sort out trader status by PM'ing AdrianFRST (entitling you to trade as you see fit on the forums) or publicise the group buy pricing by editing your original post.
Andy.
Andy.
Nothing to see here...
- andymac
- Elite Pie Master
Just waiting for someone to get back to me on a price then i will post a price for a group buy
- freak power
