ZS - SOLD
Re: ZS - update 24/1/11
jayrs :coming on nice mate.
maybe the bar is there on that boot flor to ensure the sprae wheel doesnt move around? maybe it clamps up against it, although i cant see the need for it as ford would just make different wheel trys like they did on the mk3, so if its not for that, i dunno
could be only thing i can think of stop it htting the floor. it wired because theres only a bolt to hold it on at one end, the other it just slots into a whole and is loose within the whole
- Minstral
- Your car: *
its not there to make anything stronger then thats for sure
Tbh they must have under rated them seen plenty of zs on rolling roads making 115hp standard in fast ford mag,
The 1.6 se is a hidden gem imo, I'd have one over the 1.7
jonyb4 :Tweek :Jony, your 1.8 is only 130 spec, wouldn't say it has "more power"
Cossie/ST brakes coupled with braided lines are good for track and emergency stopping
someone failed maths...
130spec= 130ps at factory, the Zetec s has 99-105ps depending which year it is, therefore it has less
Ive never seen a 130 spec zetec make 130, in standard form.
Im sure we could all enjoy quoting estimated bhp all day. I suspect yours and Tobys would turn out to be nearly the same bhp if they were rolling roaded.
- hb69
- Your car: Fiesta 1.1 LX
only one way to find out sadly
or a drag race but thats not strictly scientific
but no, i disagree completely sorry
Jony, just put the damn thing on a RR and end all this!
- Ratspeed
Ratspeed :Jony, just put the damn thing on a RR and end all this!
tell me about it! im dieing to do that, might just get £35 and go to my local regardless,
Re: ZS - CLEANED 4/2/11
well i finally decided to wash the zs today. i washed my mums the other day and it just looked so bad next to it. hadnt washed it since i last detailed it and posted the pics up on here.
i only rinsed it and shapoo'd it the dry'd it. from were i detailed it last time the dirt came straight off and was left with an awesome finish again.
before all dirty
quick wash and rinse
then after using some dodo juise shampoo and drying, all clean!
also i picked up some fiesta st brakes the other day so hope to fit them at the weekend, and i picked up a new areil from the same bloke as mine was all cracked.
old one on the left
fitted
so should have another update soonish
before all dirty
old one on the left
fitted
- Minstral
- Your car: *
Looks lovely Toby So much better when its clean! Keep it that way!
- - Danny Boy -
- Your car: Fiesta Si 2.0
- Smo
Smo :How bad is the old aerial? Still work OK?
worked fine. is in Henry's bin though now if it hasnt been colected yet ask him to have as look
- Minstral
- Your car: *
- Smo
Smo :Yeah, if it hasn't gone, could do with that!
Only for smo ill go through my wheelie bin
- hb69
Aww, thanks
Toby, do you know how much your rear springs lower it by? Like, are they meant to be -35mm, -40mm or something?
- Smo
Looking good. Once you detail a car its so easy to keep it clean with a quick wash.
Which Dodo juice shampoo did you use?
- fiend
Looking really nice again mate
- Dave G fsi
- Your car: Mk1 FRS and FRST
come up well, usual with your washing you make it seem like an art
got your hands full there with it being black
Sort that front grill out, it let's the car down!
Otherwise I'll bring my paint round tomorrow and do it while you're not looking
- bakewell001
Smo :Aww, thanks
got to about 40mm i think. i found out after some research that weitec sold a half coilover kit which is why i have the front but not rears.
fiend :Looking good. Once you detail a car its so easy to keep it clean with a quick wash.
born to be mild aaron, smells so good
http://www.cleanyourcar.co.uk/wax/dodo- ... d_490.html
cheers Dave n Jon, i was only gave it a quick once over but i was suprised it came up so well after the second wash
Steve i actually took the grille apart yesterday to check what i needed and if it could be saved without buying a rip off price on ebay as they go for so much. turns out i only need the back plastic and a new badge. ill order one soon
- Minstral
- Your car: *
Awesome, I've never used that one. Was on my list as next to buy.
I have the Dodo Juice 'Sour Power' smells like apples.
- fiend
- hb69
Toby looks like a homeless person whos stumbled across a fiesta with its window open and climbed in.
- MK2 Jamie
Toby, you look like a Mk2 driver.
- EUFez
EUFez :Toby, you look like a Mk2 driver.
few other dogy pics will come up soon after our day today. st brakes are fitted and henry and steve and smo came round prior to going to bluewater.
- Minstral
- Your car: *
ST brake fitting photos
Steve undoing the wrong wheel
Mad camber
Fitting the most annoying clip ever
Respraying the front grille.Its all in the prep work
Next area for spraying masked off
Hammer bought into the equation
Brakes on
Hoses on
Brake fluid is required to bleed the brakes, off to the shops
I waited on a brick
With the floating car
Smo turned up
Brakes bled, pondwater out
Steve enjoyed pressing the pedal
Brakes on
Back from bluewater, trying on the show wheels
Poke
Smo wanted them for his new project
Then we all went home
Mad camber
Brakes on
Hoses on
I waited on a brick
Smo turned up
Brakes on
Poke
- hb69
Good times, but some dodgy pictures!
- bakewell001
Awesome photos
That's not Smo though surely? he never comes out
- Tweek
- Your car: VW Golf GTD
Cool pictures Toby, the ZS is looking awesome. Definatly want to buy one soon once I guess my 2 NCB's.
- EUFez
Tweek :Awesome photos
He was there. He came and gave us gloves and talked about apples and pears
- hb69
- Smo
comical, why was steve undoing the back wheel for?
happy with the upgrade?
Smo :Berk
it is good james alloys will probably be up for sale the show wheels as im thinking of changing plans
good pics henry we will have to do the rear lines at some point
- Minstral
- Your car: *
jonyb4 ::lol: comical, why was steve undoing the back wheel for?
Toby has 4 braided brake lines so we were going to change the rears too, but then Tony changed his mind
- bakewell001
