ZT (CVH Turbo) piston ring gaps question.
2 posts • Page 1 of 1
Haynes says that piston ring gaps must be:
CVH Turbo
Compression rings . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.30 to 0.50 mm
Oil control ring . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.40 to 1.40 mm
Zetec 1.8 litre
Top compression ring . . . . . . . . . . . . . . . . . . . . . . . . 0.30 to 0.50 mm
Second compression ring . . . . . . . . . . . . . . . . . . . . . . 0.30 to 0.50 mm
Oil control ring . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.38 to 1.14 mm
Is standart(N/A) ring gaps are good for Turbo engine? May be for turbo conversion gaps must be a bit bigger than N/A?
CVH Turbo
Zetec 1.8 litre
Sorry for my bad english...
- disc
When i do them i do them to 18 thou and piston to bore clearance of 1 thou over manufacturers spec just so there's no chance of skirt drag as a turbo engine produce's alot more heat then a N/A engine.
- freak power
