zvh and zetec bottom ends
16 posts • Page 1 of 1
is a zvh and zetec turbobottom ends they same??
could i fit a zetec head on a zvh bottom end??
- SEG1
- SEG1
- SEG1
yes mate you can...and obviously you will turn it back to a zetec.you will however have to change the water pump and cam belt tensioner back to zetec ones as well.plus to do a zvh conv. you have to block four oil ways in the face of the block,these will need unblocking....alot are welded but some have metal plugs in them ...........hope this helps
- FRSJON
- SEG1
if you had a zvh turbo bottom end and you want to turn it back to a zetec turbo then you would have to do what i have said above.....its basically a zvh reversal ..does that help..
- FRSJON
FRSJON :plus to do a zvh conv. you have to block four oil ways in the face of the block,these will need unblocking....alot are welded but some have metal plugs in them ...........hope this helps
would i need these blocked because im going to run a turbo??
or do they only block these because they are using a cvh head?
- SEG1
there you go you both got there in the end i dont blame you wanting the 16valve head back on can someone tell me why you would have 8 instead of 16 valves
dont hate the playa hate the game
- si 16valver
what modifications will a zetec engine need to take a turbo on?
apart from lowering the compression and making the manifold and inlet fit of course.
- SEG1
- SEG1
- SEG1
RS_seg :what modifications will a zetec engine need to take a turbo on?
Good job you're a member on the best Fiesta site around hey? Open your eyes
http://www.fiestaturbo.com/articles/zetecturbo/
