zvh engines
6 posts • Page 1 of 1
zvh engines
what would the compression ratio be from using the std 2 litre zetec e bottom end and using the cvh head un moddified the head is from a h reg 2i
im after running it safe so i can run a turbo
- MK4 Rick
- Your car: Mk5 Fiesta
Re: zvh engines
it will be a high compression ratio, safe only for low boost, fit a decompression plate or get the pistons skimmed if your cheap or buy proper oversized pistons and get the block bored
- SiZT
Re: zvh engines
Shouldn't skim the 2 litre pistons and decomp plates are at best a bit bodgey. Some people have used Vauxhall C20 LET pistons and had the rod reworked to accept them.
Re: zvh engines
yeah, LET pistons are cheap, forged, lower the compression ratio and increase capacity, little end just needs widening for gudgeon pin
- SiZT
Re: zvh engines
SiZT :yeah, LET pistons are cheap, forged, lower the compression ratio and increase capacity, little end just needs widening for gudgeon pin
yeah and how much would all that cost??
- crazycage
Re: zvh engines
most god machine shops should charge no more than 100 for the lot, i know ian howells ( area six) charges around 80
- garyhurn77
