ZVH engines
25 posts • Page 1 of 1
ZVH engines
OK, just been reading a post on RSOC about ZVH's, now everyone says you can;t get 300 bhp out of one dure to the CVH head not being able to flow enough air. Thus the major limiting factor a any CVH could well be it's head.
Now you can fit a CVH head to a Zetec bottome end (you have to block off some oilways, change the crank pully etc) and it works. Now my question is, can you fit a Zetec head to a CVH bottom end?
It seems, pretty straightforward - instead of fitting everything off a CVH to the Zetec, fit everything off the Zetec to the CVH and block off the oilways in the head instead of the block.
- bcracknell
- chumkila
- Dirty Post Whore!
I'd have thought that you could fit the head no problemo, but whats the point?
The Zetec bottom end is used because it's stronger.
You may as well just fit the whole Zetec engine.
The reason people keep the CVH head is because it then retains the manifolds, turbo etc etc.
- grahamb
just curious about why it's not been done (or has it?) it'd be like a sort of opposite ZVH......could be fun..
- bcracknell
- chumkila
- Dirty Post Whore!
the limiting factor even in zetecs is the head
and problems getting over 350bhp with a zetec head
thus u need a new better head
- MadcatCraig
- BANNED SELLER
its just about gettin the flow right with the right valves etc. it can be achieved using the zetec head.
- chumkila
- Dirty Post Whore!
at least it'd bring the bhp limit upto around 350bhp... plus you get 16 valves, and not much to change. hmmmm already got a sorted 1.9 bottom end.... could have the first 1.9 Cetec Turbo.
does the FRST EFI inlet line up ok on a zetec head?
I know the exaust has to have some extra holes drilled and tapped - not a major problem... c'mon guys lets hear you thoughts I may try this come the new year
- bcracknell
yep the FRST EFI inlet line will be ok on the zetec head but it will needed to be modded somewhat to run power anywhere near 350.
- chumkila
- Dirty Post Whore!
If you ever forget his number, it can be located at http://www.zetecturbo.com
- chumkila
- Dirty Post Whore!
the frst inlet does not line up with a zetec head
an adapter plate is required
Ian Howel sold one to B19 TRB he has a black S2 and has a 16v turbo in it
this didnt fit at all as he posted in the general section - this plate cost him £35
the best thing to do is get a cvh gasket and a zetec gasket see how they line up and get a plate made.
a Zetec bottom end is stronger than a cvh
the crank is larger and stronger it has a high pressure oil pump oil spray jets alloy sump etc etc
10 years of engine development speaks for itself
- MadcatCraig
- BANNED SELLER
- chumkila
- Dirty Post Whore!
well sort of chum
when he was round mine last week he said that the ports on the gasket dont line up, thus the ports on the plate and head dont line up.
anyway £35 for a plate i think thas a joke
get the 2 gaskets find an engineering company they will make you one for a tenner cash
- MadcatCraig
- BANNED SELLER
MadcatCraig :well sort of chum
pimsle! - If you think it's a joke then why pay for it and instead didn't you lot make it yourself at home like you said in the post above + if it's as easy as you say it is not disputing that it's not easy however you should of made your mate one!
IMO £35 isn't too much money for it, the metal, the time to match the gaskets up and paying someone a score at a engineering company to make one up....£35 sounds very reasonable to me but then again people on here clearly know better.
Thanks - Sunny.
Do you have any idea what 178.8mph feels like in a Fiesta? 2000 lb of pressure per square inch per second pushing back on your face. It feels like god himself is trying to rip the skin off your skull while someone lands a 747 on your chest.
- sunnyFRST
lol sunny why buy one when you know someone who has one, then which u can clearly copy
it cost me about £8 to have a waterpump plate made for a ZVH including buying the gaskets so i think £35 is a bit steep hey im a tight ass
was just a bit dissapointed when lewis told me his IH plate didnt fit
oh i didnt pay for it either
but make one of my own i will now i know wot it shoudl look like
- MadcatCraig
- BANNED SELLER
- Mexi
It costs £35 [ERRR] its made out of aluminum thats about 20mm thick, and just for the aluminum is costly by itself.
A water pump plate for a ZVH is made out of mild steel and is very cheap to make.
£35 for the adaptor is a good price, if you want to make one yourself then take a Zetec inlet gasket to a machine shop and ask them how much it will cost to make a copy of the gasket in aluminum 20mm thick.
May cost you about £40-50.
The reason Ian sell them for that price is because he has about 10+ made at a time to save on cost.
- Andy'sFRST
my zvh pump plate was made from ally not as thick as that mind
this need not be an argument if it had fitted correctly i would have no problem but it didnt
you spend your £35 i will have my own made
- MadcatCraig
- BANNED SELLER
MadcatCraig :my zvh pump plate was made from ally not as thick as that mind
I was talking about the inlet adapter being thick not the water pump plate
- Andy'sFRST
Ian,
I bet you're using the Series 3 Focus inlet manifold with FRST injectors on the Focus fuel rail, aren't you?
Otherwise, how the fap???!
Craig,
You? A tight-arse?!? Noooo, I won't hear such lies
Peace out and Merry Crimbo folks
Craig,
- Project
- fiftyoneCL
