Zvh flywheel ?!
Zvh flywheel ?!
Postby tin-ribs on Wed Feb 15, 2017 9:06 pm
Hi,
I'm using a cvh efi turbo flywheel on a 2.0 block. The only problem is is that the gap on the back of the fly wheel isn't lining up where it should be to create a spark ( crank sensor ).
Any suggestions as the fly wheel will only bolt up one way but all the guides are saying its the one to use ?
tin-ribs
Your car: fiesta rst
Re: Zvh flywheel ?!
Postby tin-ribs on Thu Feb 16, 2017 11:20 pm
Problem solved
tin-ribs
