ZVH Pistons
15 posts • Page 1 of 1
ZVH Pistons
Right.
Apparently, according to vauge sorces if you do a ZVH turbo convertion on a 1800 lump then if you have the block bored out from 81mm to 83.5mm then you can use Calibra pistons and turn it into a 1900.
Just wondered how much truth there is in this and I assume you use Calibra Turbo pistons.
Any help would be appreciated.
ANDY
ANDY
- Low Down And Dirty
- Location: Andover ish Drives: RS1800 and Overfinched Range Rover
83.5 is a massive overbore....and Calibra pistons are 86mm anyway, ie, 2.1 ltrs.
If there were 3.5mm pistons avilible, theres no point as the block walls would be too thin, stick to std pistons, they are okay at 18psi if setup right. And 8.3:1 as std
First EECIV 'plug n play' SECS S8
- PhilM
By using standard pistons does that mean they don't need plaining or anything like that?
R.I.P Rob...
"The Teenage Chicks Love The Car"
- TrekkieFRST
- Location: Kings Lynn Drives: Honda Prelude Sex Appeal: 52.30% Loves: Stuff!!!
not that this is gonna help but i've been told that the standard pistons r good for 14psi
1 problem with that is i dont know if they need to be skimmed or not as a few different 'motorsport' companys have told me yes and a few say no
i'd like to know aswell cos i'm in the middle of building 1
- HappyHippy
standard pistons might be good for 14psi boost but personally i dont think they would last for long...the way that i see it is if your gonna spend so much money on doing the conversion in the first place, i would go the full way and do everything properly...
calibra pistons will make a 2L zetec bottom end turn into a 2.1l bottom end. U also have to have the conrods modified so they can mount on the crank or the pistons properly!
bassboy
bassboy
- bassboy
- Authorised Trader
i would NEVER run cast pistons under boost, its cheap and nasty!, what would u rather have, a powerful engine u know aint gonna go bang, or have to worry about it everytime u cain it!.. Its a bodge!..
- snake
- Trainee Burger Flipper
- Your car: ford
Andy(lowdownanddirty)
My engine was built by HT Racing. They have used calibra turbo and Sunny GTi-R pistons previously.
John
John
Quantum H4 2.1 ZVH Turbo - FOR SALE
Group4 Escort MkII 2L 16v
- Quantum John
Quantum John. Have you got any more info on the pistons that were used, eg do the con rods have to be changed ?
ANDY
ANDY
The mahle 86mm forged pistons that i mentioned are also known as "calibra turbo", can get the rods modded and fitted to the pistons locally also, not 100% sure on price for fitting to rods, but i'll find out, fark all i expect
CR in a Zetec turbo 16v is in the region of 7.5:1, thats what i've been told, will find out soon (need to know mself the exact CR), but the are suitable for use in 2.1 Zetec turbo 16vs, they are the "common" piston everone refers to, anone ith a 2.1 has them really. (Other Forged Pistons such as Accralites usually come in 85/85.5mm - 86mm = mahle forged )
- PhilM
Sorry Andy,
I don't have any more info other than some work was done to make them fit. Sounds like PhilM can help you with specific's
John
John
- Quantum John
